I have a 2001 jetta 2.0 engine, I had just spent lots ofmoney again, - replace air flow meter, theromstat, sensor, coolant housing - after all that last frinday when i went into the car after work I started to smell gas, I drove and wind the glass down, it is not leaking however it is a high smell. - kindly adivse - urgent, urgent - kind regards,
Gasoline doesn’t have to drip, or form wet spots, to leak. It can evaporate without ever hitting the ground. There is a gasoline leak in the engine compartment and it’s going through the cowl intake vent into the cabin It’s probably a fuel hose, and should be inexpensive to fix.
