1996 4.0 with new battery starts often starts fine, but then… sometimes hot or cold it throws a total hissy fit. Like a kick back or detonation it stops cranking or the whole engine shudders. When it starts it idles rough a few seconds and then is fine (like my first wife). This wore out 1 starter. I replaced the idle air valve, computer, and checked the fuel injectors for leaks, and tried a lot of prayer. No lights come on. The water reservoir loses some water and I thought it might be a head gasket or block problem but he oil is clean and no smoke in the exhaust. I pulled the thermostat to flush the system before using K&W nano to seal a leak n case fluid is getting in in a cylinder.
Am going to check the plugs to see if any are wet.
Anyone seen this problem?
