My problem is with my truck not starting. It has a history of missing when first starting up, especially on wet days or on cruise control on a flat grad. Today I started it up and it missed a couple times as it normally does. I went down the road and it missed a few more times, then it died all together. It turns over easily and I hear the fuel pump kicking on. Also, after trying to start it for a few minutes I smelled fuel from the exhaust. Seems to be getting fuel, although I am thinking it is the fuel pump. I have a bad habit of running on “E” but there is at least 4-5 gallons in the tank. I do run the tank lower than that ofter and rarely put more than 5 gallons in my tank at anytime. I know that this could cause problems with junk in the fuel lines and possibly causing a clog in an injector. What do you think I have going on and what are some things I can try.
Related topics
| Truck dies while driving | 12 | 2158 | June 28, 2019 | |
| 95 GMC Sierra cranks;no fuel | 4 | 2527 | April 16, 2011 | |
| 95 GMC Sierra won't start | 2 | 1002 | June 2, 2010 | |
| 2013 GMC Sierra 1500 - Missing | 1 | 481 | August 2, 2018 | |
| 98 Mystique occasional trouble starting | 4 | 574 | January 19, 2008 |
