I have a 99 Plymouth Voyager. Randomly and more often than not the instrument panel goes dead. I have checked all fuses and cleaned and checked the connections on every wire end I can find. Anyone else have this problem or know a tip?
Have you checked the connector that ties to the instrument panel? It may be loose. If that is ok then I would check the power to the panel. The gauges may have a tie in with the BCM but I’m not sure of that.
How about the ground circuit?
