My 05 dodge caravan instrument panel just die. No light, speedometer, gas gauge and others just not working, all stay at zero… No light, no turn signal etc… Where do I start? Somewhere in the internet discussed that it may be bad bcm?
First off check the fuses for any blown ones. If they are ok then I would suspect a connector to the panel has come loose. You most likely would have to pull out the cluster to check that.
The BCM does control a lot of the things on the panel but hopefully it is ok and there is just a connector problem.
Most likely a bad ground on the printed circuit board on the panel. Usually, just re-flowing the solder joints fixes it.
Yes, a fuse was blown. I replaced it and it works for now. Thanks so much. I am glad it is simple this time.
