My ignition has become a little stubborn… I put the key in and have to move the steering wheel until the key turns…
Should I replace the ignition at this point?
You can try cleaning it (NOT WD-40) us a zero residue cleaner. This is likely to work if you or someone else has used something on it before. Next step would be to drive to a real locksmith shop and have them check it. They can quickly determine the problem and likely give you both the best services and lowest price.
