… you may be getting a recall notice relating to TPMS battery failures.
Vehicles recalled: 52,340 Chrysler 300s, Dodge Challengers, and Dodge Chargers from the 2022 model year:
- Chrysler 300—5,658 sedans built between Sept. 7, 2021, and June 9, 2022
- Dodge Challenger—19,345 coupes built between Aug. 23, 2022, and June 10, 2022
- Dodge Charger—27,337 sedans built between Aug. 23, 2022, and June 7, 2022
The problem: The battery may prematurely fail in the TPMS in certain vehicles, which would cause the system to fail to identify if a tire(s) loses air pressure.
The fix: Chrysler and Dodge dealerships will inspect and replace the TPMS sensors, if necessary, free of charge to the customer.
How to contact the manufacturer: Chrysler and Dodge will notify owners via mail starting Sept. 2, 2022. Owners of affected vehicles may call the automaker at 888-327-4236.
NHTSA campaign number: 22V504. Chrysler’s number for the recall is Z68.
I wonder if there’s a dashboard warning for a tpms battery failure?
On our Camrys the TPMS light will blink for approx. 1 min. (I think) then remain lit vs. just lighting up as with pressure loss. I know my 2013 Camry needs at least 1battery, but I don’t need tires yet so I just old school it. You know actually physically checking the tire pressures.
When one of the batteries failed on my Corolla, the low tire indicator came on. I don’t see why something similar wouldn’t happen in this case.
Page 79 of the 22 Charger owners manual
Your vehicle has also been equipped with a TPMS
malfunction indicator to indicate when the system
is not operating properly. The TPMS malfunction
indicator is combined with the low tire pressure
telltale. When the system detects a malfunction,
the telltale will flash for approximately one minute
and then remain continuously illuminated. This
sequence will continue upon subsequent vehicle
start-ups as long as the malfunction exists. When
the malfunction indicator is illuminated, the
system may not be able to detect or signal low tire
pressure as intended. TPMS malfunctions may
occur for a variety of reasons, including the
installation of replacement or alternate tires or
wheels on the vehicle that prevent the TPMS from
functioning properly. Always check the TPMS
malfunction telltale after replacing one or more
tires or wheels on your vehicle to ensure that the
replacement or alternate tires and wheels allow
the TPMS to continue to function properly
