A couple of things here. Bird strikes are greatly reduced with the new generation of turbines because of the lower blade speed. It still happens but not as much as it does with the older smaller turbines with the high speed blades. Some wind farms are a composite of technology. The older turbines on the lower levels with newer generations of turbines built on top of them.
The older technology turbines have a host of problems, but many of the wind farms using them were just small scale test beds. I really don’t know why they just don’t take the old turbines out of production and dismantle them.
The real problem with wind technology is phase shift. Actually that is a big problem with our whole grid system, not just wind farms. Early on, AC proved to be far more efficient for the transfer of energy on electrical grids, but that was when electrical grids were independent small area grids. As the grids became interconnected and began to cover much larger areas, the problem of phase shift becomes a big issue.
For example, electricity at 60 Hz has a wavelength of about 3100 miles (186,000 miles per second / 60). Electricity generated at a power plant in Portland, ME would be a full cycle behind the generator by the time it reached San Diego, CA. That would be OK if all electricity in the US was generated in Portland, ME. but its not.
If a generator in Portland, ME was generating all the electricity and Chicago, IL decided to generate its own electricity to supplement to power coming from ME, it would sync its generator to the incoming phase, but as that electricity begins to work its way back to ME, it would begin to go out of phase with the incoming power. At some point along the way, it would be so far out of phase that it would block any power being generated in ME from going to Chicago.
The practical solution to the long haul grid is to go back to DC, but there is a lot of resistance within the industry to do that for some reason. It would cost a lot to begin with.
As for Tesla and the new battery plant, I heard that the new plant doesn’t just make more batteries, it will make a new generation of batteries that gets about twice the energy density from the same amount of materials. Its more of an evolution in the technology than a revolution, just a better design. That should cut the amount of batteries needed in the newer model, therefore cut the cost and materials.
You also have to take into account the exotic materials used in building the rest of the car, like the carbon fiber bodies. He will need some new advances in that area in order to really reduce those costs. If you put a small 4 cylinder ICE with a CVT transmission in the Model S, you would still have a high power to weight ration, great performance and great fuel economy, but it would still be an expensive car.
