i just replaced the clutch in a 94 mitsubishi 3000GT. i was driving it around and everything was normal for about 10 min. then i noticed the clutch pedal was getting harder to push down. soon it got so bad i couldnt push the pedal down to activate the clutch. i got a friend to press the pedal while i bleed the slave. the clutch then worked fine for a little but within a few minutes i started having the same problem. i just replaced a hydrolic dampener for the clutch and the slave plus hydrolic lines. the master is only 4 months old. what could be causing this problem? and how can i fix it.
Related topics
Topic | Replies | Views | Activity | |
Clutch or tranny | 10 | 1227 | March 8, 2008 | |
New clutch kit, new slave cylinder but clutch still slipping | 52 | 3694 | December 8, 2023 | |
Hydraulic clutches | 10 | 889 | August 12, 2008 | |
Rev but no power? | 10 | 1451 | March 2, 2014 | |
Soft Clutch Pedal | 7 | 4419 | August 22, 2011 |
