How to find lug nut specs?
I’ve got an '05 Dodge Ram 1500 pickup. I am so confused by the lug nuts. I tried every socket at Autozone and none of them seemed to fit right. The 23mm gets the job done, but it’s loose and goes crooked. Now the threads are barfed up. I bought some new nuts that looked right ( M14-1.5). They start to go on, but then they seize up after a few turns. I’d like to replace the nuts or at least clean out the threads, but how do I know what size?
http://www.gorilla-auto.com/pdf/GAG10.pdf
A quick search shows the size to 9/16" - 18. Have you tried a standard socket?
Awesome. Thanks! 9/16? Yeah, that is a little random. I thought I had tried all the standard sockets. Looks like it should be 7/8. I’ll have to try that one again!
Nope. 7/8 doesn’t fit. It’s really close, but a little bit too small. The nuts are in good shape on the outside. That should fit. I wonder if my socket is defective.
Try a 19 mm socket.
It sounds like you’ve cross threaded it, you may need to replace both the lug nuts and the studs. They should go on 99% of the way by hand. Can they?
It sounds like you’ve buggered up the studs
I also looked it up, and you’ve apparently got sae studs and lug nuts, but you tried installing metric lug nuts. That was a mistake
Chase the studs. If it doesn’t clean them up, then you’ll have to replace the studs
Those nuts you bought are wrong . . . return them or throw them away
Get new lug nuts with the correct sae threads, as was mentioned earlier
The next size up from 7/8" would be a 15/16" socket, by the way
The correct socket size is 7/8", however the stainless steel caps on the lug nuts become damaged/distorted from people using incorrect sockets.
Questions like his can always be easily and freely answered by your local dealer’s parts department. Ask nicely and they’re always happy to help. At least that has been my personal experience.
