Where is the horn on a 1996 Dodge ram 1500?
Have Leroy press the button while your head is under the hood.
I like Need a Horse’s suggestion…
Generally they’re located on the front of the radiator support. You’re likely to have two, in two diffent tones.
You should have a two tone duo horn mounted on a bracket in the engine compartment passenger side bellow the air duct over the wheelhouse extension. Unless had fall when you were driving. I also have a Dodge.
