I am trying to locate the horn (no not the one on the steering wheel) on my 2004 Buick LeSabre. I am assuming it is hidden behind or under something, but I have looked thoroughly under the hood and have no luck. Any help would be greatly appreciated.
The horn assembly is located at the left front of the vehicle. The bottom plastic shroud may require removal to gain access to the horn.
Thank you. That should be the guidance that we need. The horn just died and replacing the fuse did not fix the problem. Any idea what I might be up against?
