Any Honda mechanics out there? I have an 04 Accord coupe with the four cylinder engine. The only thing I don’t like about the car is the stiff ride. I’m wondering if I can switch the springs with springs from the sedan to give me a softer ride without to much trouble?
I suspect the Sedan springs to be even stiffer.
You may need to get custom springs for this. And since you have struts it’s NOT going to be an easy job. While you’re at it you might as well change the struts since they have to be removed anyways.
