So… as fate might have it, a few things are going wrong with my car just as I am about to make the last payment! I start by informing you that i have a 2005 Honda Accord.
Problem 1: Now that is is finally getting below freezing and I am having to use my heat, and I have noticed that it will all of a sudden blow ice cold air. It does not matter if I am idle / accelerating / decelerating. I must provide a disclaimer… I have not had to use the heat in the car since I purchased it Certified Used from the dealer in South Florida. After moving back to where it actually gets cold I find this issue. I had my trusty mechanic look at it and he flushed the heater core. That is problem 1.
Problem 2: For about 6 months now my car has been doing this odd shaking routine. It happens probably every time I am out driving. When it starts to shake, I can prevent it from dying by reving the engine. It does not matter if I have just started the car, am sitting at idle or if I am driving down the road. No check engine light or malfunction indicator light has come on the entire time. It feels like the car just runs hard, not nice and smooth like it used to. I have brought my car in to the trusty mechanic three times now and he can not find any problems. I did notice this morning that while sitting idle at the stop light, my car had its little epileptic shake and then stopped and the RPM’s dropped to 500. Later when I arrived at my destination, while sitting at idle before getting out of the car, the RPM’s were at 2000. I have routinely put in fuel injector cleaner additive when I fill up with gas… maybe once a month. I usually fill up with regular gas, but will occasionally fill up with premium. This whole situation is blowing my mind!
Any helpful advise is greatly appreciated! People are starting to think I am crazy when I tell them whats going on!
