This clicking/clattering noise only occurs when making a right turn in 2nd gear, it does not make any noise at all while turning left. My independent Honda mechanics and I are stumped. Please someone help me.
Thanks
Note both L and R CV axles have been replaced and they are ok.
Are you sure it has to be in second gear or could it be that you are just usually in second gear when the other conditions (turn speed & torque) are all there?
I would suspect a differential or more likely IMO a CV joint going.
Yes it only occurs in 2nd gear and only when turning to the right.
Also it’s a 5 speed manual Honda accord 1990
Can you isolate the noise when it’s on a rack?
