High beams come on when signaling right
I have a 2004 GMC Yukon SLT, 2WD.
At night, when I signal right, my high beams come on. After making the right turn, my signal disengages and the high beams return to low.
Now I only make left turns at night. Any ideas?
The multi-function switch, which has been problematic on some GM vehicles, is undoubtedly the problem here. If you replace it, your problems should be over.
