problem with heat, right vents cold and left vents hot, in tucson 2005 after service of all fluids.
Thanks, Tom
Got to be a blend door problem. The symptoms indicate that the hot coolant is going through the heater core and the fan is blowing…the blend doors must be routing the air all to the left.
