Help! Turn signal problem
Help! I have a 2003 Dodge Caravan and the turn signals and running light will not work when the headlights are on??? Any ideas?
Your Caravan has what’s called an Integrated Power Module.
This module controls all the functions of the exterior lighting.
Looking at the wiring diagram, this would the be first component I would suspect to be causing the problem.
I put a fuse in the fog lamp and it worked and then it stopped working
Those lights are also controlled thru the Integrated Power Module.
The multifunction switch is common to both problems.
What is a malfunction switch? and where is it?
It’s on the steering column.
If the lights you are talking about do work when the head lights are not on then I suggest you check the ground to those lights for a bad connection.
