I am the owner of a 1995 Saab 9000 CSE Turbo. I purchased this car a year ago and have enjoyed it up until now! The blower motor for the cabin stopped working out of the blue. I have talked with a friend that is a mechanic and we tried to trouble shoot the problem. The motor fan works only if I “jump” it to the battery. I have replaced the blower motor resistor which was what my friend thought to be the problem. It did not solve the problem. After doing further research on-line, I found that the Automatic Climate Control will give error codes when two buttons are pushed. I have gotten an error code that says that the cabin fan temperature sensor is faulty. I have since replaced that part and still have no cabin fan. I do get heat or A/C but no fan to blow around the air. The Automatic Climate Control does act as normal. I am at a loss and would like some advice as fall and winter are coming and I need to have the heat and defrost features as I live in Michigan. Please help!
Thanks,
Brandon
A meter and a few minutes and a wiring diagram will allow you to trace where the power stops. I would guess there may be a relay somewhere, or that automatic climate control is going crazy. They seem to do that a lot more than I would like. Glad I don’t have one.
Things are never simple with Automatic Climate Control. You have a plethora of sensors and solid-state devices so troubleshooting is a job for the Saab experts. You can fumble around some more, take it to a Saab dealership, or simple hotwire the fan to a separate switch.
I assume you have checked the fuse for the motor already. There may be a bad relay in the circuit that is the cause of this trouble. Having a test light probe at least to check for power is really necessary for this kind of trouble. Otherwise it is a guessing game.
A look at Saab “Parts & Service Information” Issue: 10/95-633 is a 6 page bulletin on “Subject: Correcting Complaint of Failed Fan Control/Fan Resistor” covers your problem. A sluggish ventilation fan can draw excessive current. A “New fan control, with load cut-out, turns off the ventilation fan under certain driving conditions.”
Use the bulletin to check the ventilation fan amperage draw, and go from there.
So the error code is no longer being displayed?
