Help identify wiring and relay 2006 2.0 cruiser
I’m looking to identify these wires from the 2 replays and also a wiring (i know one is ground but to where?) from by the brakes. Thanks! i can only post one pic ig cuz I’m new. I’ll try to post more or just email me ! slipknothollywood@gmail.com
Are you looking to identify all 5 wires, or just the yellow one and the 2 small ones?? where is the white one and the green one going?? might have to open up the wiring loom to find the 3 remaining wires…
Without a wiring diagram, you are just going to have to keep digging, they should be close to were the big white and greens ones in the wiring loom, just gotta dig…
Aftermarket wires and relay. Someone tried to make an “improvement”. Follow the wires and see what they are connected to.
its cut off and the end is to the relays, I’ll take a better pic.
Its cut off
If the wires are cut, just follow to both terminated ends and remove them. If the device they were connected to is missing, then your work load is cut in half.
Going by just the colors I’d say trailer lights.
Looks like a trailer harness and isolation relay to me…
