it has heated seats , are they to get warm when I use the remote start , if I had the seats set on warm when I shut it down or is it different option > thank you
If you do not use the remote to start the vehicle are the seats on for heat . If not then it will be the same way for remote start. But since you have a 2019 if you can’t find the answer in your manual call the service department and they will know or can look at a vehicle like yours. I myself would not want the seats to turn on without me being in the vehicle .
