Hard pulling
I have a 2004 Suzuki Aerio with a 2.3 4 cylinder 5 spd. The problem I’m having is when I accelerate the car pulls to the right hard the steering wheel turns about 5 degrees. When I left off the throttle the steering wheel comes back to center and I hear a pop and feel coming from the passenger front. It also does this while I’m at speed I can hit a bump in the road and get the same problem. I just gave the car an alignment and the issue got worse now my whole car feels like it shifts to the right and left
Sounds like a bad engine mount
I agree. You’ve got a broken motor mount
This complaint of torque steer can also be a sign of a loose suspension part such as a lower control arm.
