unfortunately, i’ve gotten to the point that i can’t diagnose this myself. my mechanic just throws parts in and hopes that it solves the issue. he barely listens to me when i tell him whats wrong.
anyone know of a decent diagnostician in brooklyn or anywhere close? it’s a fuel or sensor issue and isn’t starting correctly if that helps.
Check out mechanics files on the Car Talk Home page, bottom right, if I recall correctly. Put in your zip code and see if any recommendations fall out.
Perhaps you could provide a complete description of the car, the problem, and what has been done to try to fix it or diagnose. Then folks might be able to give diagnostic tips.
thanks cigroller, i think you’ve already seen my other post in which i describe what the pos is doing.
