One fairly simple way to confirm the no start is due to lack of fuel is to spray some starter fluid into the throttle body air intake and see if it will start up immediately and run at least briefly. If so, fuel starvation at start up is definitely the problem. I have the sense you need to get some hard data on what the actual problem is in order to make much progress getting it fixed.
Related topics
| Van mysteriously won't start sometimes | 38 | 49805 | May 10, 2019 | |
| 1988 Ford F-150 - A fuel pump every other month | 5 | 884 | June 16, 2019 | |
| 93 f 150 Do i need a new fuel pump? | 14 | 576 | May 16, 2018 | |
| Where is the fuel pump relay? | 9 | 943 | January 11, 2009 | |
| Its Not the fuel pump | 14 | 76968 | November 24, 2011 |
