Change Fuel Filter
Yes, change the fuel filter.
Yes, I am trying to find out where it is located and how to replace
Maybe you want to mention that in your question.
Its located in one of the fuel lines. Between the tank and the fuel rail.
One of the parts stores – Autozone I think – has some part location diagrams on their web site. Check there maybe.
Be aware that you will spill a little gasoline – probably a cup or less – while changing the filter. Depending on your temperament and situation, you may want to prepare yourself with a drip pan and rags.
And eye goggles are well worth wearing as well.
it could be in your gas tank. you have to take the rear seat out and then on top of the gas tank there should be a cap where the pump/filter reside.
