I cant seem to post pics here but anyway, im trying to change my fuel filter on my 2003 4.2 v6 f150.
The side of the fuel filter facing the cab has a normal joint i recognize, where you take the disconnect tool, lets say thats the male end, and it plugs into the joint and pops the filter off the fuel line. Almost looks like the mouth piece for a trumpet.
Now the other end facing the gas tank has a plastic line and plastic connection. I do not recognize this joint. Do i need the disconnect tool thats circular and just clamps on the line there?
Do the Ford designers do it that way – rather than just using screw-on fittings – b/c it makes it possible to remove and re-install with less clearance?
Thanks guys. Once I remove the white retainer clip, does the fuel line come off by hand or do I use the standard disconnect tool like on the other end of the filter?
Just got it done. Easy! I wish all ends were like that. Way easier. Good thing I did it, looks like original owner never did and it came out brown on the gas tank end. Thanks everyone
