High Mileage 200k plus, 5 Speed.
Past 25k miles, car will stall at will. A couple to few turns of the ignition and will start right up. Car runs great otherwise. Can be very intermiten. My mechanic replaced “fuel module” under dash about 6 months ago. Problem actually got worse - and now is running fine and at will.
Fuel pump is the next most likely suspect. A good mechanic can diagnose the failure only if it is failing, try what we did, stop at the dealer every time you go by and hope for a no start problem, had the fuel pump replaced under warranty after 3 tows, and no problem by the time the tow got it there.
