still having trouble truck want run more then about 15 mins where is the fuel pump ecelerater on the 92 ranger fuel injection truck has plenty of power will start right back up just want run more then 15 mins
What is your last fuel filter change?
Warms up, then quits. Looh for a condenser / capacitor on the outside of the distributor. If you are lucky, there is one and disconnecting it will allow the truck to run. I don’t believe there is one on 92 models. I made two cars run by cutting the wire to it. It looks like a firecracker.
prob never been changed as far as i know where is it located inside the fame
ok thank u i will look for 1 if there is can it be changed or does it not need it
