How do I replace the serpentine belt on a 2000 Ford Focus with z-tech engine and no AC?
My recommendation for a question of this nature will always be to stop by the local parts store and get a repair manual. I would. Proceding with any job you’ve never done should always be to instructions. In the case of a serpentine belt the manual will also tell you things like how to check and adjust the tensioner, and that stuff is invaluable.
- mountainbike
Never mind, folks. Once I got underneath the procedure was obvious and easy. Then, after I was done, I found my Haynes…
