I’m checking here with the experts for a friend of mine. She said that the air conditioning on her 2001 Ford Explorer only works when her car is in idle. She said that when she steps on the gas the fan continues to work but doesn’t blow cold air. If she stops at a stop sign it works… and so on.
She has taken it to a shop that specializes in air conditioning and he checked and cleaned off a few connections (whatever that means) and thought that would do it but it didn’t. She is going to go back this weekend.
I told her that I would think that a specialist would see the idle/drive issue as a good clue as to what the problem is.
Any thoughts are welcome and I will pass them on. I will follow up with the result after she gets it repaired.
Thanks in advance
