i just need to see if anyone has an assembly diagram for a ford axode transaxle…i’m rebuilding mine i just need to see where this on flat bearing goes
Here is the only view I have.
~Michael
You can order an ATSG manual for that trans which would most likely tell you what you want to know.
1-800-245-7722
Is this a smaall round needle bearing you are trying to locate??
transman
