I used to have a 99 Mitsubishi Montero. There is a spring-loaded metal contact behind the steering wheel that presses against a metal ring attached to the wheel. Put some silicone grease under the spring and your noise problem should be fixed.
Related topics
| 2000 Mitsubishi Montero Sport Suspension | 0 | 431 | May 25, 2010 | |
| Suspension Question | 8 | 899 | May 27, 2010 | |
| Montero Noise | 7 | 807 | July 11, 2019 | |
| 2002 Mitsubishi Montero Sport rear rattling | 1 | 868 | July 27, 2018 | |
| Montero rubbing noise from the steering shaft | 1 | 568 | December 14, 2008 |
