F150 Troubles
2005 Ford F-150 4.2L suddenly gave me troubles yesterday. Happened not while driving but when I tried to start it up, it did start but the engine was shaking and it immediately died. Today it didn’t start and later it did start for a second but again died immediately.
So It does turn over, it’s not the battery or the starter. It seems to be either a fuel system issue or a timing issue. I plugged in a diagnostic tool and it gave me no codes.
I tried replacing the fuel filter which didn’t solve the problem. I’m thinking it’s probably the timing chain but if anyone has any thoughts I would appreciate the help.
you need to see if you are getting fuel and spark. do you here the fuel pump turn on?
are you getting spark to the plugs>
The crankshaft position sensor may have failed.
https://www.1aauto.com/content/articles/bad-or-failing-crankshaft-position-sensor-symptoms
The fuel pump failed. Pound on the bottom of the fuel tank with a mallet while someone cranks the engine.
My vote is for the fuel pump. At 16 years of age it’s had a good life unless it was replaced already.
