So I just got a f150 2006 from my pops. He says every once in awhile it idles rough. Well it did it today and I captured the error code p0345 with several others all referring to misfiring. Anyone have experience on this one?
It usually points to a problem with camshaft position sensor circuit.
Yeah I found that but I guess from what a read and a few videos I watched. Those sensor rarely ever fail and tend to never be the true cause.
Was hoping someone might have some experience with it.
So that means the wiring to the sensor is where you should look. Start at the connector and inspect the pins Work back from there.
I’ll give that a go, thank you sir!
