2008 F-150 23,000 miles still under warranty.
55 degrees outside & trying to run the vent, first noticed that the temp switch had a hair trigger, and at no point able to be comfortable, going from hot to cold.
Before bringing this in for warranty work, is there anything I can check, or just have Ford look at it?
Thanks
This is kind of a no-brainer. The vehicle is still under warranty and the vent system isn’t working correctly? Let Ford figure it out.
