Will I damage my car’s paint job if I use “Softscrub” to remove those pesky cement-like seagull droppings?
read this before you ruin the finish on your car…
Thanks!
The universal solvent, ie water is quite effective, saturate a paper towel and let it sit on the spot should work. Keep up with a protective finish also, ie wax.
