Exploding Passenger Mirror?
I was driving down my street. I saw what I thought was a bright light coming toward my passenger side window.
This happened at that time.
The back cover came off and landed by the curb.
I didn’t hit anything.
I looked for evidence a projectile but saw nothing.
I’m baffled.
I didn’t hear a noise. The mirror wasn’t really moved. There’s no mark on the back cover.
I truly don’t know what happened.
I hope I posted in the right area. I’m brand new here.
Blown Up Mirror?
I have no more clue than you do what caused that. Mirrors generally don’t spontaneously explode. That white light may have been something that struck your mirror… UFO, maybe? Clearly it is unidentified.
A collision repair shop should be able to fix you right up. Give your insurance a call, it may be covered
Welcome to the forum…
Judging by the “fin” on the outer A pillar of your truck (it’s a 3rd gen aero thing), I think you are driving a 3rd gen (2016-2023) Tacoma, but please confirm…
Anyway, I am on probably the biggest Tacoma forum out there and I have not seen what you are describing… To me it looks like a pellet (gun) hit it, is there a mark on the inside of the cover that fell off???..
It is a 2017 Tacoma. I’m sorry,I thought I mentioned that.
Maybe a pellet gun …that didn’t even occur to me. I’m going to look at the inside of the cover right now.
You might be able to replace just the mirror part, is the rest of it damaged or just popped apart?
Thank you. It is a 2017 Tacoma.
Maybe a pellet gun …that didn’t even occur to me. I’m going to look at the inside of the cover right now!
It just popped off. It snapped right back on- after I found it! That would be wonderful if I can just replace the mirror!
Here it is:
2017 TOYOTA TACOMA 3.5L V6 Outside Mirror Glass | RockAuto
Thank you!!!
My advice is replace just the broken part yourself . . .
And don’t overthink just why it happened
Replace it and enjoy driving your 2017 Toyota Tacoma
Thank you :slightly_smiling_face:
[quote=“Mustangman, post:2, topic:200881”]
Had my 2006 Nissan Altima mirror destroyed when I went to church and parked on the side of the road. .
Yea, insurance company replacement it but I’m not sure if my premium was increased as a result.
The parts listed on rockauto.com are cheap
This is well within the realm of projects a diy person could tackle
Seems to me leave the insurance for the big ticket high labor stuff, imo
Agreed, just make sure your order the correct mirror, I think it is a heated mirror, but not sure about blind spot monitor, you should know, if you need help finding out which one you have just ask…
It reall6 doesn’t matter how it happened. I’ve had good luck with Rockauto. The three I bought are exact matches to th3 original. I kept getting in a hurry and knocking them off on the sude of the garage. The last time I just bought the rjight and left set to have on hand. A little over $100. Might need to be painted but less than an hour work, you’re done so not the end of th3 world.
I replaced the mirror on my wife’s van about 15 years ago I bought the replacement at a local auto glass shop.
I would guess it was one of two possibilities. First possibility is your mirror was hit by a semi-solid object like a baseball or softball, judging from the outside portion of the mirror having significantly more damage and the baseball/softball/similar object would not have damaged the side housing of the mirror. And my other conjecture would be; if you have heated mirrors and they were accidently turned on and with the summer heat, that mirror just shorted out and the “bright light” you saw was the electrical short circuit of the heater element…
Bur my money is on a flying object like a baseball, etc. hitting your car and the “little scams” playing ball across the street disappeared as soon as they realized they hit your vehicle….
And the flash of “Bright Light” was only sunlight being reflected off the falling mirror… Just be glad what you saw was not the “bright light at the end of the tunnel…” L o L . . .
