I hurt my back several months ago and could not drive. I ended up with a dead battery. I got the car running last week but I threw a code: P2067. Any idea what this is and what might be wrong?
Thank you so much!!! --Bernie
Sometime if the battery voltage gets low the car’s computers can enter a state where they sort of work, but not entirely, and act like they are confused. If nothing else seems to work to fix this problem, try disconnecting the battery overnight. That will allows all the car’s computers to reset, cross your fingers, might do the trick.
Hmm?
The dead battery didn’t seem to reset anything. ![]()
Tester’s the car expert here, not me. If he says disconnecting the battery won’t work, probably won’t. Just an idea is all.
Thank you for the tip…IT WORKED!!!
Sincerely yours,
BerndEhorWoloszczak
