Engine stalling
I am experiencing engine stalling while driving my 1996 Grand Cherokee, after it went low on gas about 6 weeks ago.
Any advise?
Thanks,
Onelove
It may have sucked some sludge into the fuel system. Tanks have nasty junk floating around that you really don’t want in your system.
It likely will need at least a new fuel filter but you could run some techron fuel additive through a gas tank right before you’re about to fill it up. Do that a couple of times. It may or may not fix it but it is a cheap thing to try.
It could also be that the fuel pump is having issues. They are cooled by gas. It running low on gas could have caused this older pump to overheat somewhat.
Does it happen a lot and does it start right back up?
