Engine dies
I have a honda accord 1999 4 cyinder automatic. my problem is, while i am driving along my engine will die, there is no wornings when is dies i can put it in nutarl and start it back up. speed doesnt seem to be a facture it will die at any speed.
You may have a faulty ignition switch or power connection to the ignition system causing this trouble. Try tapping on the suspected areas with a screwdriver handle to see if you can make the engine die.
