I have a 1984 Caddy coup de ville.  The 4100 engine is on its way.  I want to know what is compatible as a drop in.
 4500?, Northstar? 350ci of some sort???
 Thanks in advance
I’m guessing the 4500 and 4900 will swap, it’s the same block. You might call a parts recycler (AKA junkyard), they have interchange catalogs that might help. I doubt the Northstar would be a drop-in.
I believe that the 350 was an optional engine that year, or years close to it with the same body style. The 4100 wasn’t a good seller so Caddy began to offer the Chevy engine as a more powerful option.
