something is draining the battery on my 1993 Escort. I think I isolated it to the circuit with the radio memory and powertrain control module(PCM). Where  is the pcm and how do I check it for a short?
 Thanks
If it was a short it would be blowing the fuse.
It’s not a short…just something is drawing a lot of power. Doubtful the radio memory circuit can draw that much current to effect the radio. Not sure about the PCM though.
I fear that your test methods would damage the pcm. It’s time to turn it over to the repair shop, since it’s evident that you need data (a repair manual and wiring diagram) and skills which you don’t have. Reality is.
