I have a 1996 pontiac grand prix. It should have drl and if i’m not mistaken automatic headlights also. the drl do not work and i’ve checked all fuses and everything is good fuse wise. none blown or missing as far as i can tell. I can not figure out why they are not working. I have a sensor in the dash that i believe is for the automatic headlights. I’m not sure where to go from here as far as trouble shooting. I have a code reader if that will help me but I have no lights on my dash indicating a problem.
If your vehicle does have DRL’s and they’re not working, then the most likely suspect is the DRL control module. This mounted behind the let side of the instrument panel.
is this something i can get to fairly easily or does the dashboard need to come out?
