I replaced my shocks today just because I felt like it.
I am not sure the old shock was even bad. It was just rusty on the outside.
When I compress the old shock with my hands, it seems to have the same amount of resistance as when compressing the new one.
But, I did notice the new shock expands/decompresses much quicker than the old one.
Does this mean the old shock was bad? Or does that not matter?
If these are gas charged shocks, it means the new ones are expanding as they should, and the old ones either weren’t gas charged, or the charge had leaked.
I’m assuming you’re compressing the shock, and then just letting go (not pulling it apart).
The real question is whether the new shock is harder to decompress with force than the old one. It is the decompression motion that defines the shock’s effectiveness. But a difference in gas charge could make this difficult to determine.
Passed a 318ti on the hwy the other day. His front tire was bouncing noticeably. Hard to yell out the window at 60mph his shock is bad. He probably already knew.
What you are experiencing is the very low speed damping control that is different between your old shock and your new ones. The new ones may use a different type of valve design that the originals so they don’t react the same as the old ones while hand stroking. Since you can’t test them on a shock dyno, you have no idea the damping force they develop at all speeds compared to the originals. They likely have higher force at slightly higher speed than you can extend the shock.
Your new shocks will work fine, don’t worry about the hand stroking forces. They don’t really matter. Just for reference, I spent 20 years as a shock absorber engineer.
