Can you drive with a wet belt? I replaced my coolant and oil filter gasket so coolant and oil all fell down over the belt and front of engine. Thinkiong of spraying down degreaser and power washing the front.
Now does the belt need to be 100% dry before I start the car and drive or? Don’t want it to come of and shred and get into the main seal.
Spray some simple green everywhere down there, let it sit for a few minutes and spray down with a power washer.
Brake clean evaporated to quickly and I can’t hold the can close enough, need to at an angle or else only the propellant comes out and not actual cleaning agents.
Water or coolant on the belt won’t do much harm, but oil might cause some problems. What I’d do in that situation is just wash the belt off with warm water and soap, using a sponge. Maybe tie the sponge to the end of a stick if that’s easier. If you can’t access the whole belt at once, crank he engine briefly to get it to rotate to other segments.
