dodge neon codes p0111 anyone know how too fix this code or what part i need code is from a dodge 2003 neon
the IAT,internal absolute tachometer,is very easy to replace,step 1 remove oil pan ,and find the reluctor wheel located to the front of the engine ,just clean the sensor and reinstall the pan top oil and your done.
hope that helps
good luck.
Intake Air Temperature Circuit Range/Performance Problem
It might be the MAF/IAT sensor.
It could be something as simple as the intake air temperature sensor electrical connector not being plugged in.
