The gauges, oil, fuel, rpm, mph, automatic locks on dashboard do not turn on when I start the car, nor do they register any information while driving.
What could be happening? The car drives okay. What should I do? Is this problem easy to fix?
Do the lights on the dashboard light up?
My guess is a ground wire. Also make sure the dimmer is not turned down.
Check the fuses. Also check the connector to the dash.
When this occurred with my Volvo, the culprit was a bad ground connection. I suspect that you have a similar problem.
