I hear that if you stick an RF TV remote in your mouth, a head big enough will act as a parabolic antenna, allowing you to control your neighbor’s TV.
If you then have a bunch of big headed friends stand behind you while you have that remote clenched between your teeth, it becomes really directive. In a pinch, it could be used as a lethal particle beam weapon.
The way it was explained to me was. This worked if you had metal fillings in your mouth. It is using the metal as a boost.
Next are you going to do the discussion on the wives tale of, if you are locked out of your car and call someone with your second remote, put your phone near the door lock, the remote will unlock it over the phone?
