The light in one of my gauges has gone out and I cant figure out how to change out the bulb. Anyone out there know how? Thanks!
It would help if we knew the model year, and if you’re talking the gauges in the factory instrument cluster, or an aftermarket add-on gauge pod
it is an add on aftermarket pod made by diesel dynamics it is on a ford f250 superduty 2001
Is the gauge pod mounted on the A-pillar panel, or under the dash?
In any case, you’ll have to remove the gauge from the pod first, perhaps there is a philips screw on the backside of the gauge?
I think on some of these gauges, the bulb is soldered onto the circuit board . . .
It is on the A pillar panel. will go take a look at iit again.
