"99 Marquis,141K, decelerates to 30mph & will only accelerate after an incline.
So far hv replaced fuel pump,alternator,battery (after low voltage readings), and had major tune-up. Catalytic converter tests ok.
HELLLLP Pls. I’m running out of hills…
Thanks
You have a bad automatic transmission. Or at best the trasmission fluid is low, which of course you should check first.
If the engine races when you can’t go over 30, then it is the transmission.
However, if the engine doesn’t race, then it is an engine problem.
Is the check engine light on or flashing?
Have you cleaned or replaced the MAF sensor?
Have you checked the TPS?
Have you verified fuel pressure (maybe a bad fuel pressure regulator instead of fuel pump)?
You did replace the fuel filter, right?
What did the old plugs look like when you did the “major tune-up”?
Have you done a compression test on each cylinder?
Hi
Thanks so much for yr thoughts…
Engine doesn’t race…a little stressful groaning or low whining.if I try to pump.
no lights at all
fuel filter replaced
Old plugs were shot, gapped at 85 rather than 35
will inquire as to the rest of yr questions on Monday ,obviously I know ‘nuttin honey’
& am at everyone’s mercy.
Appreciately,
Mirmax
Hi
Tranny lookin’ good so I’m told …
Thanks for thinking for me.
Mirmax
